andy27168 said:Hi, My first thought is that one of the batteries is knackered or a possible blown fuse, this is what I would be looking at first if it were my car.
OneForTheRoad said:most of the convenience functions wont work when your main battery is on the way out . the dash will warn you of this . check your small battery under the pollen filter for a date , if its way way old renew it . I'm taking mine off this winter for a full inhouse charge .
guydewdney said:gear module failure stopped my 'hold' fuction. relatively easy swap esp on a 7 speed version
