w211 panoramic roof
t567wab
Croydon
Vito 122 Sport X
Anyone would know if 2008 facelift pano roof fits 2004 pre-facelift?
Can't see the reason why not but want to double check.
Roof mechanism on mine needs to be replaced and 2008 its the only one I've found.
Any info appreciated.
should fit, sure it isnt just the motor cog?
It lifts up but doesn't slide back. It sounds like motor is working fine but maybe linkage got stuck?
id get a indi to open it up and have a look first before you spend any money buying anything
Unfortunately Graham at PCS confirmed it.
Not even thinking to go to the dealer.
Had the guy from sunroof repair co. to check as well. Same verdict. 2008 pano it's the only one I've found
if PCS has had a look at it , then time to buy one!
ask graham to check part numbers to confirm it will fit, I cant see why not
