GlynC
Just had my E320's alignment checked, previously adjusted a few months ago after I noticed abormal tyre wear. Last one didn't seem to make any difference so I took it somewhere else this time.
Excellent advice from the chap doing it who knew his stuff ( Watford if anyone wants the details) but I was appalled to find out that MB don't fit the adjustment bolts to allow the camber of the wheel to be adjusted which in my case appears to be the main culprit in the inside edges wearing. Expensive tyres at £200 a throw too.
I phoned MB dealers to be told that this is correct and they will have to check it -cost £163+vat and then if required fit the bolts required and adjust the camber angle to suit. Cost on top of the check etc.!
Probably £300 + by the time the have added on the cost of the oily rag wash!
Has anyone else come up against this..? Would have thought they would have fitted the required bolts it's almost certain to want adjusting at some point. My car has only done 19,000.. no kerbed wheels or damage.
Any help welcome!
Any help welcome!
