Robiduff
- Oct 26, 2013
- Location
- Norway
- W220-320 CDI 2001/W126-300SE 1988/W126-280SE 1985
I took out the compressor and tested it, it ran ok. so i put i back. i saw the cable to the motor was a little burned in the connection. so i celaned it. then when measured the cable to the motor there was no power supplied. the fuses are ok, the relay is new, and the motor for the pump works, but there is no power in the connection to the pump, so maybe the cable is damaged?
