My vehicles has 79k mikes I have it serviced regular and do long journeys. At last service I had oil breather and pipe and seals replaced and had the Intercooler pressure checked and cleaned, to give longevity to EGR, Turbo and prevent oil / soot build up in Inlet pipes. I had noticed it go into limp prior to doing this, but it was an isolated incident. No check lights etc.
However recently whilst on long journeys I noticed that I lose boost but I manage to keep the car above 2500 revs to keep momentum up to stop me going at a snails pace from going into limp mode. As soon as it drops to 60/70 mph you’re stuck at no boost, until switch off and on. The car drives fine around town it intermittently goes into limp mode but ive never had CEL check light.
Read codes on a Snap On Solus
Ultra
2359 Charge pressure control. Too low boost pressure
2385 EGR control. Mass Air too large
2696 Check component B60/1 (Left exhaust back pressure sensor) Control variation - The exhaust back pressure too high
DPF Menu Live Data
RPM idle 700
Ash content 6
Soot content of DPF. 77.6
Distance driven single last regen. 181
B60 Exhaust back pressure sensor
HPA 1238
B28/12 Left Pressure Differential sensor DPF HPA 800
B28/13 Right Pressure Differential sensor DPF HPA 15
B28/8 Pressure differential sensor DPF HPA 15
I’m guessing the charge pressure low boost and EGR Mass Air flow deviationis triggered by the faulty high back pressure fault.
It’s clear to see the Left pressure sensor is reading very high, 800
I want to know if it’s faulty sensor and where exactly is it located ? Is it on Left bank manifold ? All threads I’ve read mention one sensor in Turbo and the second near DPF under transmission tunnel.
The DPF soot seems high, the car did complete a regen 181 miles ago when I drove back from London yesterday, Ive read that DPF regen relies upon readings between the sensors being compared but a faulty sensor prevents regen,
I attempted the forced regen after viewing the 70 % plus soot in DPF but it kept failing to perform the regen, error locating signal.
I want a 2nd opinion pls, am I on right track focussing in the left pressure sensor ?
Is this preventing the completion of regen of DPF canusingtge 70% plus soot ?
Ultra
DPF Menu Live Data
RPM idle 700
Ash content 6
HPA 1238
