Hope this is in the right place, I've posted on a few forums without much luck so hopefully somebody here can help
I have taken the plunge and purchased a 2006 69,000 mile S320 CDi
Now as the car has not done a lot of miles and did lie up for a bit so I have been slowly working my way through various gremlins (most fixed with a new battery) - however one that has not gone away is the occasional fault about the ABS not working etc - my mechanic had it narrowed down to either a faulty sensor or the ABS ring on the rear axle - after testing the sensors and finding them ok, he got a good look at the ring and says its corroded and would need replaced
Before I go into that is there anything I need to know - ie how hard is it to get at the ring, any special tools needed and what sort of strip down is needed - I am considering doing both rears at the same time as if one is bad the other can't be far behind - we did clean it a bit and it helped for a while but the errors are back again. any pointers would be helpful
