AbbieCadabra
hmmm, getting a little confused & am not overly impressed with this at the moment!
before i purchased from cleanstore, i checked how to use the wash & wax that they sell, do you use diluted or neat? i got a bit of a garbled reply advising a ratio for using as a handwash with a bucket & also a ratio for a smaller amount (which i presumed would be the container capacity for the machine i'd referred to). i specifically said this was for use with a nilfisk.
the washer has come today & there's no info at all on detergent use & the bottle for the wash & wax is only 500ml, the smaller capacity they'd quoted was 2.5ltr, so i was left a little confused...
i've just rang cleanstore, asked for clarification & have been told to use the solution neat as it's only mixed at low pressure with the water. i can dilute, say 50/50 if i want, but might not get best results. he also said you can use any old wash & wax solution in the bottle, doesn't have to be specifically for pressure washers.
just to double check, i've called the manufacturer of this particular brand that cleanstore sell & they've just advised it's not for use in pressure washers! apply via a bucket, diluted, & then you can jet wash off.
am i being really stupid to expect that a solution that is sold by a pressure washer place should actually be ok to use in a pressure washer???
