There's a bit of a 'known issue' with the S/W switch leaving W active even in the S position, so I'd be cautious about playing around with it unnecessarily! There are several threads on how to take it all apart to fix the switch contacts, my R129 has gone into W mode a couple of times and it's pretty annoying.
Note also that in the standard S position the gearbox holds onto gears longer when the engine is cold, to help it warm up more quickly. W mode doesn't do this so I wouldn't personally use it on a regular basis. It works great on wet grass though (the one occasion I've used it)
