On removing the rear wheel arch liners from my R129 4 of the 6 studs sheared off.
One will be an easy repair as it took a 30mm circle of the panel with it so I can easily weld a bolt to the back of the repair panel. The area around the hole is still good metal.
I am looking for suggestions for the others. I don't think there is access to the back of some of them.
I have seen a possibility on a parts image for A 0009901210 as a parts kit repair but I'm not sure how that works.
My other option is to attempt to weld on a bolt to the wheel arch.
I'm sure I am not the first to have come across this problem so any suggestions are welcome.
