Hi just went to fit some amg alloys to my 2004 clk and the wheel nuts seems to be too long. Does anyone know what size I would need? The bolts I have at the moment are the standard ones half threads half smooth. Thank you
Sorry what does the m12 m14 mean? I also notice on the amg the bolt holes are alittle wider, would it still be ok once bolts on. The alloys are the ones in picture
The bolt which is on the car are half smooth and half threaded. I just check mine m12x1.5 and the ones for the wheels are 14x1.5
If I get shorter bolts will it be ok or there be too much play??
You need to have the correct bolts for safety - you don't want a wheel departing at speed! These people really know their stuff and will be able to supply the correct bolts.
