Wheel bolts
Tyreburner
Northumberland
Clk320
Hi my first of many questions.
When I bought the car it came with some receipts, and stapled to one of them was a list of things wrong with the car :-( the one I wanna sort first is :- not all wheel nuts the same size and alloy wheel spigot bushes are missing?
The car is a 2000 320clk.
Can you guys please tell me how long the wheel nuts should be? The wheels are aftermarket dotz mugello?
I have tried searching but the answers have me confused lol
Also are alloy wheel spigot bushes spigot rings? If so any ideas what sizes to get??
Thanks in advance
Mick
You want Spigot Rings. Take the car to a decent tyre/ wheel fitter and they will tell you the correct size. That depends on the wheel Center bore size and the hub center bore size.
They will also get you the correct bolts. You probably have a mix of original Merc and OEM. One has a rounded lug the other a taper. I think you need tapers.
Thanks for the reply I unfortunately work such hours that only kwik fit or ats would be open,so need to try and get it sorted via t Internet.
I think I have worked out . . , tapered, 17mm head, 26 mm thread m12 x1.5 ???.
Can anyone else post anything to confirm this before I buy some
Thanks in advance
Mick
Mick
If you are going down the eBay route getting the seller to tell you the figment for your car/wheels.
Or.
Google Dotz they should also know.
Or.
Call or email Tyremark in Sittingbourne Kent. They are a Dotz agent and will help. The boss is a big Merc fan.
+1
