Number_Cruncher
>>a small amount of engine oil on the stud and a small amount of engine oil between the nut and built in washer
Lynall, I've been around trucks for long enough to regard those nuts and the spigot mounted wheels they are used on as modern! I can well remember many stud failures, and thankfully a smaller number of complete wheel loss incidents. If you look at the official VOSA figures, commercial vehicle wheel loss remains a problem.
Stud failure was so common, we kept them in stock!
>>i wonder if 210 e55 350bhp has same size bolts as e200 150ishbhp bet it has!
It's actually an emergency brake application which is most likely to cause slip, and so, both vehicles will produce remarkably similar brake torques before the wheel slips, and hence, the same design of wheel bolt is applicable for both.
