HITECH
Use your local garage you always use. There is nothing diffirent to servicing an old car to servicing a new car. The principles are exactly the same. Especially more so if you presently have had no problems with the car. Then your usual garage mechanic will be quite thorough with your 2016 as he was with your old peugeot. I used to be in that position where I was only servicing 10 yr old cars or more. I had to advertise to people that I have the technical and mechanical ability to service and repair brand new cars aswell as older cars. People are under the mis-conception that with a new car with a warranty you HAVE to take it to a certain dealership. This is completely untrue. But im not saying that you should not take it to the dealership or that the dealership will not do a good enough job. Ofcourse they will. They have everything they need and they only work on the same cars over and over again so you WILL get an outstanding service. If you can afford it then its fine. If you cant then it does not mean you are neglecting your car by going to your local garage man down the road. He will most likely have the ability to think outside the box and be able to troubleshoot a problem aswell as give your brand new car a new lease of life with all the dealership branded parts. I see too many scare tactics with motorists saying WOW YEAH U BETTER GET IT TO THE DEALERSHIP, THEY THE ONLY ONES BE ABLE TO DO IT PROPERLY. well let me tell you. Them days are LONG GONE and it is an open market.
Hi All,
I bought a 2016 Mercedes C200 petrol last year. Before that I had an old banger Peugeot so I just took it for servicing at my local garage.
In the new year the Merc is due its first MOT and A3 service. It has done 22,000 miles and I haven't had any problems with it over my last year of ownership.
Where should I take it to get it serviced? I don't fancy taking it to an official Mercedes garage as the costs of servicing appear very high. So I could take it to a local mercedes specialist or just my normal garage round the corner.
Also, what should I be asking to have done? The A3 service as per the manual involves all sorts of things that probably don't really need doing like replacing all the brake fluid etc. I understand that if you don't do everything as per the servicing recommendations in the manual then the value of the car can depreciate more than it otherwise would. But I'm expecting to own this car until it dies and isn't worth anything- like maybe 8 or 10 years from now so this isn't really a major consideration for me.
Clearly, though, I want to maintain it properly and make sure that it does last. But I want to do it as cost effectively as possible.
Any recommendations as to garages/ what type of service I should be getting?
I like in Harrow.
Many thanks,
Jonathan.
