chrisk2010
It was the non-reducing nature of the particles in the Nanotech SST that piqued my interest. This allowed me to vary the choice of polishing pad to alter the degree of abrasion whilst the cutting power of the polish remained constant. Given that you can't put back what you've taken off, it is wise to start with the least abrasive pad and see if it is producing the desired result. If your clearcoat needs minimal correction then your blue pad will be fine. The green pad is slightly coarser and is actually the one Mercedes use for any corrective work on their production lines. Here a link to help you get a grip on Hex-Logic pad selection:
A Guide to Chemical Guys Hex-Logic Pads
Given that 99% of the gloss is actually achieved at the polishing stage you could put that blue pad to use for a final jewelling polish if you are sufficiently OCD. This is where you let the DA traverse the clearcoat using just its own weight whilst your hand supports and guides it. This allows you to achieve a crisper finish prior to adding your protection.
Thank you for all the great advice Toobad this is really interesting stuff !
So i could use the green pad with the Nano tech first then switch it up to the blue for that finishing shine and let the pads and the weight of DA do all work in removing the fine scratches and swirls.
Would you then use the Poorboys Glaze followed by the Fusso Coat ?
All the stuff arrived at work yesterday including the BH Korrosol and Black hole glaze but i was already using them on my bosses Amorak.
