just to add to Andrews comments
stick with Linksys I went with dlink and had nothing but trouble with hanging laptops, networks etc. I have now swapped over to linksys wireless cards but still have a dlink router & modem. The setup is now working great.
If you don't go with the ISP stuff then beware! Not all ADSL routers have the modem on board
I got stung by this trick and I was not pleased. If you go for a router and it does not have a modem on board you will need to buy an Ethernet based modem.
If anyone has the Linksys All in One Box can you post the model number?
I would recommend buying your cards from PCworld
as throughout all my problems they have consistently just taken my "broken" ones off me and given me new ones (they don't repair them so they give me new ones then sort the busted ones out with dlink) I have had about £300 worth of them at the last count (dodgy chip set in the B2 dlink card!!) the last one went at 10 months old so now all my cards in the house are running linksys with 10month + warranties :bannana:
As for hotspots...
You have to pay for access to the legal ones but depending on where you are you can sometimes find "open" networks that people either miss-configure or leave open to outside usage (coz they are nice people
) legal ones require that you have a common key to get on, meaning that everyone on that network can in theory see your data
. (not strictly true but can be done)
If you live in a built up area you should apply the following precautions with whatever wifi product you end up with...
1) Stop the wifi router broadcasting the SID (site ID) outside the network.
2) Apply Mac filtering so that only machines with Mac Addresses that you recognise can gain access to a DHCP address
3) Make sure that you use the highest available WEP or WPA encryption that the router has. In addition use HEX keys instead of alphanumeric.
128 bit WEP can be broken. But on a normal house network I doubt anyone would take the time to try. If you are in a business environment I would not use it!
Hope this helps.
Any questions just ask
Regards,
Peter
