will 19" AMG wheels fit my 2006 S320CDi
Yuppy80
Mercedes
Can anyone tell me for sure if I can fit 19" AMG wheels to my 2006 S320Cdi? 8.5J & 9.5J
SPEC/PART NUMBER FRONT 8.5J X 19 EH2 ET30 A211400 1202 A171400 0302 WITH 255/35/19 96Y REAR 9.5J X 19 EH2 ET31 A2114001402 A1714000402 WITH 285/30/ZR19 98Y.....Does this answer? sorry for ignorance and thanks for your help.
You have the link to the fitting chart above, just compare. If the ET of the wheels is higher than you need you can use spacers to fit them. If the ET of the wheels is already lower than you need then no they wont fit (unless the ET is only different by a couple of mm).
Your car is presumably a W221 S Class, so from the fitting chart above the correct sizes are:
Front: 19x8.5 ET43, tyres 255/40 R19
Rear: 19x9.5 ET43, tyres 275/40 R19
So the wheels & tyres you mention will probably not fit.
Car pictures by NewboyK1200 - Photobucket
Mine fit OK
