Hi
As the title suggests, is it possible for a forum member having access to MB WIS/EPS to kindly provide some documents explaining the process for getting access to the Driver's side park/side light bulb holder in the front headlight unit? It appears that the bulb holder is causing the park lamp to turn on and off (when lights are switched on) randomly. On some days the bulb will stay on as normal and some days it would not turn on and will throw up a bulb failure message in the screen.
Local BMW/MB Specialist body shop mentioned that access to the side lamp holder is not a simple job and if I remember correctly, it involves the removal of front wing panel?
If someone has access to the WIS, please PM me.
Thanks.
Thanks.
