Matc88
This may help some of you.
I just fixed my wobbly pedal. Just used an m8 nut and bolt. With a bit of ptfe tap.
The old plastic clip that held the pedal was loose, and seen a thread on another site.
Had to push the end of the clip in and push the plastic clip through the pedal, although this didnt work on mine so had to drill the plastic clip out.
Then just thread an m8 bolt through and tighten up with a nut.
Make sure the nut is not to tight as pedal won't come back up. Maybe a little bit of grease etc would help. I havent got any to hand but I will put somee on in future.
