OK as usual my skills at getting this sorted are rubbish!!! I think i have worked one thing out, that MB command/bluetooth/cradle system is v complex!
I have;
Command has bluetooth but not for making calls apparently?!!!??? It will connect to my iphone but my iphone says its not connected - so thats no good. Whats the bluetooth onj command actually for? Manual says you need a phone cradle aswell to make the command BT work??
The iphone cradle has bluetooth - i have followed the instructions (emailed to me by the nice chaps at Command on line
), but the instructions say that when you have established the bluetooth connection you then put the phone in the cradle?!!??!! Whats the point of that. If i take the iphone out of the cradle then command says i have no phone connected.
I have done a search here and have read that even if i did get the bluetooth connection on the cradle to work without the phone in it then i can't make and receive calls from the phone itself, i have to use the command keypad? Is this right? If so then its no good for me anyway.
I'm guessing i ditch the iphone cradle and get a Viseeo bluetooth unit instead?
All help, as aways, hugley appreciated. Please help me.
Regards,
Thicky McThick
I have;
- W164 ML with Command
- Integrated phone kit
- MB "bluetooth" iphone cradle
- iphone 3GS
Regards,
Thicky McThick
