grober
MB Master
Fuming vents
Towing a car with an automatic gearbox can damage it. It depends on the box and how far and how fast it is towed. Did your transmission problems start immediately after that? smoke and fumes from the dash vents normally indicates some sort of wiring fault causing wiring to melt due to localised heat.Could be from anywhere behind the dash and may /may not be related to your other problems. You obviously havn't found a GOOD vehicle electrician yet!
