Ok but if the head gasket or something wrong with the head inside wouldn't it run rough or different but my car runs like a champ, it doesn't over heat the temperature is fine the fan doesn't start spinning fast it doesn't smell no oil leaks but the water or anti-freeze starts to boil and starts to spit back so I'm think because my radiator doesn't get water through it and the water doesn't move so it starts to boil and heat up and begins to come back through the only way possible which is the tank for anti- freeze, or the maybe the water pump is not pumping any water so it stays in one spot
My car has 107k on it,
