hotrodder
Leaking/weeping is a common way waterpumps go when the bearings and/or seals die of old age. They can also suffer from corroded impellers and various other things either corrosion or impeller related (messing up clearances so the impeller can't pump efficiently). When something like any of the above happens it's fairly common for cooling at idle to be more affected... with a belt driven pump designed to give enough flow for idle speeds they typically flow more than needed at higher rpm most of the time so the drop in efficiency is more noticable when stuck in traffic
Sounds to me like the fan clutch is pretty much dead. The rad may be well past it's best but hotter near the inlet with temps dropping as you go across, then down and back across the core is normal. Coolant path through the rad is like
which is a double pass crossflow layout and gonna have a slightly different heat spread to the single pass type mentioned in that link where coolant inlets and outlets are diagonally opposed whether it's a vertical or crossflow layout
