hotrodder
If you're certain the gauge is trustworthy* then yeah, pump makes most sense
* A while back the gauge on mine started misbehaving randomly creeping up or sometimes (more usually) jumping about in a way that's obvious it's the gauge. In either case tapping the thing results in it going to back to normal for a while. Not likely to be the case if your gauge is reliably following a set pattern of hotter at low speed/idle and normal at higherspeeds rpm... if locking the box out of 4th, or even restricting it to 1st & 2nd, when pootling around town results in lower temps (when moving) that'd pretty much confirm the pump isn't flowing enough at lower rpm for whatever reason (impeller corroded, erosion of the ally casting messing up clearances etc as you've ruled out wobbly/rough bearings)? Can just about make out the impeller with the 'stat removed and coolant drained but not enough access to check clearances etc, only enough to tell if it's a properly rusty mess
