corned
I have just been out to mine to conduct a little 'experiment'.
The car has not been started for 2 days or so. My glowplugs are OK so I started normally and left the aircon on AUTO, but set the temp on both sides to max. Within 30 seconds, the air coming out of the vents had some measure of heat in it. In 5 minutes, the warmth in the cabin had melted the snow on the windscreen, without me setting the aircon to demist.
Therefore I can only assume that the booster in my case is alive and well. I compared this with the last time I was out in the car, when I set the aircon to demist. This gave no noticeable warmth for ages - presumably because it takes the aircon unit out of AUTO when you select demist.
As a separate and unrelated measure, I have taken the step of covering part of the radiator to see if, next time I am out and about, this improves the running temperature, which is usually down to about 65-70C or so these days.
Finally, I remembered to cancel the auto-fold on the mirrors - to prevent the possibility of damage if it tries to unfold frozen or ice-blocked mechanisms when I next get in.
