300td engine still runs when i turn key off.
jgs600
salisbury wiltshire
1998 c250 estate.. my weekend car
1990 mercedes 300td
my car has just develped a fault. when i turn the ignition off the engine still runs and wont turn off.
can someone point me to the problem
cheers
I can.
There is a shut off valve on the diesel pump that needs replacing. It looks like a bullet with a rubber tip.
Inlet manifold has to come off as well as the back of the pump. Take it to a diesel specialist if you are not sure.
