Hi Vman,
Ke jetronic with lambda was available and used on Mercedes engines since early 80's..an additional electronic sensor to minimise emmisions which gave way to the mega complicated KE jetronic.
Couple things you can check is the coolant temperature sensor, this is one of the most important sensors for the KE jet..check the wiring on the harness, if possible swap the sensor.
Sensor picks up the coolant temp and sends a signal to the ECU for "COLD START" engagement and normal operating temp.
if your KE jet is fitted with a lambda, the coolant temp sensor gives way to the lambda once the engines reaches operating temp.
The micro switch that is attached to the throttle linkage can also cause problems with fueling and fueling shut off. It has 2 functions, 1 full open throttle and fuel shut off when throttle is closed. woth having a quick look...you should be able to hear a click as part of the throttle linkage touch the switch when the throttle is closed.
mazza
