Hello all, not had to post before due to the wealth of information available, but now I could really do with some advice please.
Our C250 TD isn't starting properly, due to air in the fuel line. I assume it's probably a leak somewhere from other posts I'v read, but it's not obvious to me where or how. I am very confused as what the various pipes are all doing!
Please see picture attached. We can JUST start the car with the nose pointing down hill, and after a few cranks to get rid of the air, it starts. Once we get it going, the car runs just fine. When you switch off the engine, you can see tiny bubbles moving in the direction indicated in the photo (there are two arrows, one has light reflecting off it!). The pipe with the larger arrow has slightly larger bubbles.
Does this give any clues as to where the problem is? Definitely a seal, or could it be a valve? Or the lift pump?
Cheers,
Matt.
Cheers,
Matt.
