A few veg oil questions
mijfife
Rosyth in Fife, Central Scotland.
E300 Avantgarde TD Auto Estate. 1998
Hi all, I've been busy reading up on the various veg oil threads on here as that was one of the main reasons I bought the W210. I ran my old Scorpio on well filtered and de-watered waste veg oil for over 30,000 miles with no issues but fancied something a bit more reliable (I hope ;))
Anyway, I've a couple of questions that I hope you can help with.
1) Before I do the switch, I'm planning to change the glow plugs as the glow plug light comes back on for a minute after starting. Olivier has sent me some excellent links for this job so I'm happy to have a go, especially as I always like to do my own maintenance. I'm planning to fit either Buru's or Bosch Duraterms, if I can get an answer from Help Today! (No reply to my email but I'll give them a phone tomorrow)
Other than the Glow Plugs, manifold gasket & the big 'o' ring at the EGR valve, is there anything else I'm likely to need to replace? (please don't say the cylinder head if the glow plug snaps, I've read about this too and I'll be taking it very gently ;))
2)While I've got the manifold off, I'd like to change the oil seals in the fuel lines for Viton ones, as recommended on here. Silver Saloon, can I ask where did you get yours from? You mentioned that you had bought a big bag, would you be interested in selling me some if you have spares of the ones I need? I'd also appreciate some pointers on which ones to change, is it essentially the same as the W124?
3) I've got the heat exchanger that I had fitted to the Scorpio, I'd appreciate feedback on where others have situated this in the engine bay and where they tapped into the fuel & water pipes please.
4) I also read about removing the viscous fan, Olivier mentioned this to me when I met up with him. I'm curious why the car has both the viscous and electric fans fitted in the first place?
5) I'll be checking the tank strainer as advised prior to the switch and during the first few thousand miles.
Thanks in advance for any help, it's much appreciated.
Regards, Jim
Hi
In answer to Q3. Your engine already has a coolant heat exchanger on the fuel line just before it goes into the pre-filter.
Q4. The electric fans are essentially for the air-con. Thats my take on it anyhow.
Good luck with the heater plugs, leave tham rather than break them is my motto.
230K
Thanks 230k, I wasn't aware that it already had a heat exchanger, will need to have a look at that!
As for the glow plugs, I don't see that I have a choice, especially as the glow plug light is coming back on after starting. I'm planning to get plenty of plus gas around them and take things real easy, fingers crossed they'll come out okay :eek:
I ordered a new set of Bosch Duraterms today from Help Today that I saw mentioned in another thread. Quite reasonable at £8.40 each including vat.
Many thanks, Jim
