I was hoping somebody might be able to asist with a part number check?
I decided to bite the bullet and rip the dash out on my Clk to get the annoying 'snapping' sound coming from the Charcoal filter stepper motor/linkage.
This is now the 2nd time I've had to do this. About 2 years ago I had the same fault. Bought the repair kit (A2038300032) from MB and replaced the A32m2 Stepperv Motor cog (was split)that was in the kit. Also replaced the Stepper Motor at the same time. All was well for a couple of years then it started again. After ripping everything out I noticed that the cog wasn't split this time but had worn teeth - see picture below. The cog that fits into the HVAC housing and attaches to the flap appears to have a small piece of it missing (tried to highlight it in pen).
Could somebody put a part number to the cog on the right in my picture - it's the one that fits into the HVAC housing and directly attaches to the flap shaft. The repair kit mentioned earlier doesn't seem to include this part.
Sorely tempted to leave it disconnected however since I've gone this far with it I may as well do it properly. The flap moves freely by hand and I also swapped out the stepper motor again to eliminate that. Can't see what has caused this to happen apart from the plastic used to make the cog being too soft. note only one of the cogs has wear to the teeth.
Thanks in advance if anyone could check the part number for me.
