- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, ML63, CLK350 'Vert, E350 Cabrio, Triumph Sprint (Bike not Dolly...),
The heater is working, the aircon isn't, properly at least, if the lowest it will go is ambient. The Halfords check showed there was a problem. If the problem is only low pressure, not no pressure, you might find a DIY top-up will work, which I suspect is what you're intending to try. Good luck if you do; I hope it works. (Measuring the pressure at the LP port doesn't work for MB systems; something to do with the type of compressor, I believe.)
FWIW, my wife's Mazda MX3 had a slow leak in the system, and I had to top it up every Spring. I did it a little at a time, until it blew satisfactorily cold, to avoid overfilling it. It was fine for five years, and fine when she sold the car after that time, though I did tell the buyer about the problem.
If you have, or can borrow, an iCarsoft MB II or similar (don't know about earlier versions), you can measure the operating pressure when the system is running; 13-14 bar is what you're looking for. My CLK had precisely 0.0 bar when I bought it, so I knew it had a leak, not just low pressure.
