The laws on the use of foglamps have been around for some time, and I agree that sometimes, these rules are open to a bit of interpretation ( like almost every other law in the land, hence, solicitors and barristers make a huge amount of money interpreting the law as they would like to see it work for their client, almost every day) The Police are ( generally) not so stupid as to take the letter of the law and apply it without using some sort of discretion where it allows, hence, the use of adaptive cornering lights would be accepted as a feature of the car.
The law also states that front and rear fog lamps should only be used in conditions of fog or falling snow or seriously reduced visibility. Seriously reduced visibility means what it says on the tin, hence heavy rain and smoke would fall into this category, and use of foglights would be correct.
Causing smoke to blow over a road and case seriously reduced visibility would be the offence here!
Most importantly, it is important that they are turned off as soon as visibility improves. This might mean switching them on and off many times during a journey if necessary. Front and rear fog lamps are designed to be seen in reduced visibility and will dazzle other road users in normal conditions. It is an offence to use fog lamps in normal visibility conditions and drivers who continually use their fog lamps, because it is considered by some to be fashionable, could be prosecuted for driving without due consideration for other road users.
My favourite way of dealing with people using foglights incorrectly ( if the opportunity arose) was to prosecute the ones I saw that had one foglamp not lit while the other was working, as it was an offence not to have all lights working if they were fitted and in use.
Theres more than one way to catch a monkey! ( or should that be, `skin a rabbit!`
Allan
