- Oct 15, 2008
- wme451 a124 r129 s211 r230
New to Adblue and all its delights to come. Are all Adblue refills the same, or are there better brands to go for, in the way that some say Shell is to petrol?
Is All AdBlue the Same?
There are several different types of AdBlue.
These are differentiated by International Organisation for Standardisation (ISO) 22241 numbers.
ISOs ensure that the AdBlue you use is effective and has been created to the proper specifications.
Modern diesel cars run on ISO-22241-1, ISO-22241-2, or ISO-22241-3.
If you are unsure which type your car uses, consult your vehicle handbook.
I'll check that out, thanks. Other than the spec though, is spending more on a particular brand unnecessary, or are the cheaper ones as good if the specs are the same?Hope this helps:-
Likewise, not many around in London though.I get mine from the pump at BP. If you have to trust someone it might as well be them and it's the cheapest way to buy. Plus no spills and auto shut off nozzle.
Only one I have seen so far was at ESSO in ElginI get mine from the pump at BP. If you have to trust someone it might as well be them and it's the cheapest way to buy. Plus no spills and auto shut off nozzle.
