If it's yellow with a wavey line, it's the oil level light. Maybe they have underfilled?
It's yellow light, dealership didn't have the Mobil1 0w40 oil so I brought it my self and paid for the job.
I had 1x 5L jug and 3x 1L bottles.
They gave me back one of the 1L bottles with half the content, so they used approx 7,5L engine oil.
What type of filter? Some have anti-drainback valves, others don't. Don't know if that is true for MB but it is elsewhere.
It's genuine MB oilfilter
Even without a valve it shouldn't take 30 s to build up enough pressure to extinguish the light unless the sensor is faulty?
This didn't happen with oil lamp before I left my car at the dealership.
When you turn on the ignition all lights illuminates, start the car all lights go off, this is the correct procedure.
After I went to the dealership to get my car, I start it and notice the oil lamp is still ON after I had start my car when the other lamps went off.
Clearly they fu**ed up something!
I think the first thing I'd have done was go back to the place who serviced it.
I went there and complained a few days ago, I also went back yesterday on Friday got really pi$$ed off at them why they are such idiots not checking out the car before they released it to me.
OP , can you show us a photo of the 'oil' light you are talking about. As far as I know no V8 M113 ever came fitted with an oil pressure monitoring switch that was connected to the dashboard display. Yours might have one , If so I would like to see how to retro fit one to my car , I have seen DIY installations of switches/gauges but never an MB OEM one.
If you have something coming out of the blanking plug (circled in red here) you ill have oil pressure monitoring.
There is an oil can in the display of the oil lamp, it's amber.
It's not an oil pressure lamp.
If you want an extra oil pressure gauge you can connect through oil test port in front of the engine, I used a braided hose with fitting.
See my photo, it's 0 to 5 BAR oil pressure gauge, the others are oil temp gauge and volt meter
A few thoughts:
1. The low oil pressure warning light is red, not amber. Just making sure it's the low oil pressure warning light that we are talking about.
2. If it is indeed the case that the oil pressure takes longer to build-up after the service, there could be several reasons for that: too low viscosity oil, oil filter without a valve, etc.
3. Just on case the oil pressure is indeed low, I would let the car idle until the warning light goes off.
4. If the light always stays on for 30 seconds regardless, I.e. even when switching of a hot engine and immediately starting the engine again, then I would think it's an electrical malfunction rather than low oil pressure.
5. If the issue is indeed slow oil pressure build-up, then the length of time that the light stays on should vary from time to time depending on engine conditions at the time.
1: Must be oil pressure lamp with an oil can in it
2: I use same oil like always, Mobile1 0w40
3: I always let my car at idle during cold start until RPM drops to normal, same goes with the illuminating oil lamp until it goes away.
4: Oil lamp only comes on at start procedure never during drive.
5: Something is fishy here, oil lamp NEVER stayed ON before directly after start like it does now.
Some other things happened, I drove my car several times this week on beautiful weather.
On Thursday I went shopping for grocery, came home to leave my food, then went to park my car in my garage, so I start my car and it missed directly on start, I had to remove the key and re-insert then my car fired up at once.
Why did it miss the start???
On Friday my outer temperature display on dash went all black, only mileage and clock now work.
I know that tiptronic cars had dead pixle problems, I don't have any pixle problems on my 99 C43.
This all of a sudden problem has something to do with the other above electronic gremlins.
I suspect service guy at dealership tampered my car, they were acting really fishy towards me when I went to get my car.
All these problems never occured before I took her to the dealership for a job.
They botched everything!
