S
stargazerplus
Guest
This maybe should be in the specialist section, but the mods can move it
Just thought it might get more attention here and be of use to each and every one of you!
I am fussy who works on my cars but I decided to go to Kwikfit today to suss out their aircon service. I am really surprised to say that I was very impressed. There was a queue of customers and the independent I rang was busy for the next two weeks. Before I let them touch mine I watched carefully to see what was going on with the guy in front of me's car. I also decided to take the risk because they have a leaflet the says they would give your money back if it wasn't 10% colder... mine ended up nearly 30% colder.
The equipment they use is only two months old manufactured by Robinair in Italy, which seems to be what the independent specialists use. It is fully automatic and they enter in the make and model of car. The machine then pulls off and measures the gas (mine had 790g and should have had 950). It also pulls off the oil and holds a vacuum of -1bar fot 20 minutes. It then recharges with the correct amount of gas.
Well the difference is remarkable. They measured my car when it came in with a big probe down the centre vent for a couple of minutes, climate set to low and fan to max/air to vents. Temp was 12.9 c. After the service the temp was down to 8.3 c. The car is five years old 80000 miles and had never had aircon work.
Oh and I forgot to say that once the equipment has pulled a vacuum on th e system it does a leak test. I think £45 is a bargain seeing as all the other quotes were about twice that. Their guy had been on a training course and all they will do is refrigerant and oil recovery and recharge but the difference i todays 30 c heat is remarkable!!! And no I don't work for kwikfit...
I'm going to take the C class in tomorrow. Apparently they're only doing a trial, so I had to call HO to find out which centres has the equipment. I used the Gants Hill branch near Ilford.
