RobS280
Hi folks, didn't think I'd be pestering for help so soon after joining but I'm about ready to start tearing my hair out
The Command system on my 2005 S280 tells me none of the devices are available (Radio, CD, DVD, SatNav etc.) then promptly shuts down. This began yesterday after I had to check all the fuses (one by one) because I discovered that the engine cooling fan was failing to operate at high engine temp. In the event, I found that all fuses were ok so the cause of my original problem lies elsewhere. It was immediately after this that I discovered the problem with my audio/video system. When checking fuses I only removed one at a time, then replaced before removing the next. I'm sure this problem with Command (device unavailable messages) is directly related to the fuse check I did, but can't understand why or how to fix the problem?
This afternoon I disconnected the battery for a half hour hoping that this might restart or reset the system, but no luck.. The problem still remains :fail
