SLADEDESTINY
- Aug 2, 2012
- Mercedes 300e
On trying to trace the problem with ABS brakes I decided to check the charge voltage from the Alternator.It reads 16.13 volts. I am sure this is high which to my mind points to a faulty OVP relay. It would explain the ABS light being on and the reluctant starting.Can anybody tell me what the charging rate should be? I thought between 13.05 and 14 volts was correct?
