AMG Paddle Shift DIY
MP Steering Wheel Installed - MBWorld.org Forums
on a 56 plate im pretty sure it can be done as you already have the buttons, see the link above for w211 retrofit, it should be the same for yours.
I know Ricky_S has done this recently
BenzedUP said:
That's great, thanks for this buddy.
Do you know anyone who has done this mod before that can fit them for me?
Just whip the wheel off mate and give it a bash, whatever goes wrong let me know so I can do mine properly!!!
Seriously though, can't believe you have them and not given it a bash! I wouldn't be able to help myself!
Any chance your mate could get another set?!
When it comes to working on my car I seriously do not trust myself, I fitted the CLK grill, which took me nearly 2hrs, lol.
Regarding the AMG Paddles, it was just luck he was selling them and I just bought them off him at discounted price, doubt he will have any.
I don't think they will fit without changing the holes in the steering, the current AMG buttons have different shape to the paddle shifts I think, just need a little mod to make them fit...
I use the buttons all the time, it's just so much more fun, just gives you better control of the car.
After various threads about the paddles and the airbag removal, I thought I would post my DIY today. I was quite nervous as some threads talk of using Dremel tools and all sorts of gubbins. I had been told these would be a straight swap, and luckily they were!
Part number is A171 267 00 46
£111.55 inc VAT
Target vehicle - 2009 CLK 280 Sport.
Before:
After:
A very simple swap, took about 30mins going cautiously and taking photos.
I loosened the two Torx T30 screws and then disconnected the battery. This allowed me to turn the wheel easier to access the screws. Took a bit of time as the screwdriver I used was too long and kept snagging on the interior. A thread I found elsewhere said use a long Torx screwdriver so I bought one - I'd go for a smaller one say 10cm long. Thanks to responses to me 'airbag removal' thread I made sure not to strip the screw heads.
I also decided not to disconnect the airbag to minimise any hassle on my 10 day old car. The paddles were still easy to access and remove whilst holding the airbag, the connecting wires were long enough to replace the paddles without removing the airbag.
The new parts:
Wheel with airbag removed. Paddle retaining screws and electrical connections circled in red.
Comparison of old vs. new. Note the same fitting and same plug shape.
The paddles were a direct swap, so a straight in-out job. Refitting the airbag was a bit trickier as the Torx driver couldn't get purchase on the screws properly. I was very nervous about stripping the screws. I only tightened them losely, then reconnected the battery and started up so I could move the steering wheel easier to finally tighten the two Torx screws holding the airbag into the wheel.
Job's a good un.
Quite expensive for a cosmetic mod, but I am happy with it. I might be able to reclaim a few quid by eBaying the old paddles.
Simon
Hey Simon, Amazing job on the paddles upgrade! I know it's been awhile, but do you happen to have a photo of the back of the airbag, where does the wiring from the 3rd and 4th connector of the steering wheel contact plate/control unit on the right connect to?
Much appreciated, Thank you.
I don't use mine very often, but do find them handy to knock it up or down a cog if I need to. Just mailed MB Edinburgh for a price on a pair LOL
Last time it was the nodding dog that I couldn't live without.
