Hi people,
I have a CLK 200K and as many of you I have the famous performance problem.
My CLK was using LPG when I faced my first performance problems. It was misfiring when I was fully press the gas pedal. I changed spark plugs, ignition coils with their boots, cleaned MAF, and for 2 days everything was ok. After the 2 days misfires disappears but a performance problem now can be observed.
Problem goes continuous worst until I notice it on gas too.
I thought it is the catalyst so I removed him. Problem was going worst and I cannot use LPG as engine was shaking around. The last 2 moths I don’t use LPG at all.
At this point I followed the classic performance cure, change MAF (new, not original from eBay) and EGR valve. Problem still exists.
After some days I have my first engine lights. P2038 and some codes related to catalyst and lambda. So I put back the catalyst. After that I still take the catalyst and lambda sensors errors, so I have order one from eBay.
Until I’ll have a new sensor I take some OBD codes: P2038 again and P0204, P2000.
Do you believe new oxygen (lambda) sensors and catalyst will cure it?
Do you believe it may is something else ?
I will upload 2 screen pics from digimoto.
Please heeelllpppp
Please heeelllpppp
