312 Sprinter
There was a guy on here from the States who turbocharged a 3.0 litre W210 with a head spacer. I think Koolvin ran his turbo kit with a slightly thicker head gasket. The problem with running custom pistons is firstly they have to be made up and second there is no guarantee that the head will cope with the tolerances. There is another guy in Australia who has turbo'd a 230K engine who ran custom pistons. The guys who made them said that it would be better with the OEM piston set up.
I dont think the tolerances are that close not to cope with a 1.5-1.9 mm head gasket. I'm not running a ton of boost either it will only be about 0.5-0.6bar and even that will be set up on a rolling road.
If it works out cheaper just to use a 230K head or block then I'll start looking for one.
If you're only going to use 0.5 bar of boost is it really necessary to lower the compression ratio? I've never turboed a Mercedes engine, but I've done more than a few Volvo engines. At that sort of boost providing the fuelling is correct I reckon you'd get away with the NA compression ratio.
If you're going to use tight squish you need to get the crown of the piston to within 40 thou (imperial
I too wouldn't bother with a 5th injector, use a correctly sized set of injectors and a rising rate fuel pressure regulator. If you try to address under fuelling with a single additional injector you're almost bound to end up with the pots furthest away from it running lean or the nearest one running rich.
