The new engine isn't even run in - 37000 revs in total recorded - so about an hour's running tops. An oil change after 200 miles is for certain. You are right about the heat around the cylinders, dear old Henry designed it with the exhaust in the block, but this has huge water capacity and the radiator is being recored with a much higher capacity, and new water pumps too. The later flatheads really had cooling licked - this one has no rust or crud build up inside the block either, so I am hopeful that overheating (the cause of all the problems) will not be an issue again (digits and member crossed).
Certainly not me causing the gearbox mangling - the whole car has only done about 60 miles in my ownership! There is synchro on 2 and 3rd, but that was such a rotten repro it was ovalled before fitting!
I also suspect lubrication has not been done properly - there are 13 lubrication points around the chassis and it needs to be done regularly.
Thanks on the engine oil - it is much appreciated!
