Right... first fault has come up! We seem to have an issue with the light cluster at the rear driver's side. When I got the car, the main tail light worked, the small one in the corner didn't... i took it out to get the bulb and low and behold! it came on!
This put out the warning light on the dash.
A few days later, light is back, this time i hadn't turned the light on, just tapped the brake and yes, brake light out same side.
While taking it out to fit a replacement, i noticed the little tail light was now broken! Fitted both and while the stop light works, i now have no tail light at all on that side!
I even swapped the bulbs i know to be working from the other side and nothing... any ideas? The indicator, new brake light etc all work fine. Don't fancy a pull from the plod...
chers,
m.
chers,
m.
