Remote11
Evening all,
I am a newbi from Tamworth Staffs: Car 1999 C180 Auto
Well I have gone and got me my first Merc....however I have the BAS/ASR light issue, so after trawling threads I changed the brake switch and it has not worked.
Symptoms:
Car starts hot or cold perfectly ticks over smoothly if you feather pedal it will rev ok ish
give it some revs BAS/ASR light comes on
idle then hunts
no power
misfire (not sure but sounds like it)
If you drive the car (not easy with this problem) it sounds like it is running on 2/3 cylinders when you stop with it in D
I will have a go at cleaning wheel sensors to see if this helps
I sprayed the MAF does not seem to make any difference plugged in or not
This seems to be a common problem but I cant seem to find threads that don't relate to the brake switch
Is there something else I need to be looking for
Coils possibly?
or does anyone know where I can get it plugged in (like I say driving it is very difficult
appreciate any thoughts
Symptoms:
idle then hunts
no power
Coils possibly?
