Bas esp light
Now Repaired! Faulty Lateral Acceleration Sensor. Repaired by local Independent.
I'm having the same problem on my 99' C240T. The ASR-BAS lights up after driving a variable distance. Switch the ignition off and back on, the light turns off.
The first time the light turned on was after I passed over a bad spot of road. I was driving at the time at a fast clip.
If it's the Lateral Acceleration Sensor, where can I find it on the vehicle?
Had the exact same problem up to three hours ago. Changed the BAS control module (located directly in front of the brake servo), problem sorted.
Checklist for next time around
- Brake light switch (not all cars have this)
- Irregular rims sizes
- Broken sensor wire on one of the wheels (ABS sensor)
- damage to wiring
- Broken control module in engine bay
- Master cylinder problem
- Yaw sensor*
- Lateral sensor*
*can be 1 or 2 units.
- steering angle sensor (usually after battery change)
- broken front or rear SAM (fuse box)
- blown ESP fuse / steering wheel fuse
- Damage to CANBUS B or C
- Water damage inside car
