In order to measure quiescent current you need to disconnect the negative battery terminal. Select multimeter DC amps high range 0-20 and connect multimeter leads one to negative battery terminal and the other to the disconnected terminal clamp. Now decrease multimeter DC amps range until you get a reading, should be around 30 to 40mA on the 0-200mA range. If you get a negative reading reverse the multimeter leads.
Take care when disconnecting/reconnecting battery, you can damage the rear sam also you may need to reset windows and traction control afterwards.
My guess is that if you have excessive battery drain the culprit will turn out to be a memory seat control unit (try disconnecting each in turn, pull the plug under the seat.
I have just done some drain tests with the muiti meter, connected in series between batt.neg terminal &earth strap.Meter was set to 10 amp DC range.All elec consumers off. 1000 milli amps (ma)=1 amp.(a)
Here are the readings-
Total current drain=1.02amps=1020 milli amps
I then disconnected the following consumers (in turn one at a time)by removing the fuses(using the mb fuse card)and took meter reading
Rain sensor-fuse 9 (is this known as OCP? mb fuse card dose not list OCP,only rain sensor) 0.93a=930milli amps.1020ma-930ma=90ma drain.
Seat adjuster(drivers)fuses 2,21,27. 0.89a(890ma)
1020ma-890ma=130ma drain.
seat adjuster(passenger)fuses 1,22,38. 0.29(290ma)
1020ma-290ma=730ma drain.
I then dissconnected both driver&passenger seat fuses,meter reading was 0.13a or 130ma.
I then disconnected all 3 together,ie.seats&rain sensor fuses.Reading was 0.05a or 50ma. 1020ma-50ma=970ma drain.
My Questions are¬
1.With all the above 3 consumers disconnected at the same time, the current drain is down from 1020ma to 50ma. Is 50ma within the acceptable tollorence?
2.Do i need to disconnect the fuse(s) of other consumers to test for current drain?If so witch ones?
3.Do i need to replace seat adjuster(drivers&passenger)and the rain sensor?
4.How much are the above 3 componants?
Any additional help and imformation would be appreciated.
