striker600
- Nov 13, 2007
- Location
- south yorkshire
- 2001 c270 cdi avantgarde estate Auto w203
Autofix,The first meter i used was a cheep wickes own brand(oh dear)which was fused up to 250ma,thats why the fuse kept blowing as my car had a drain of 1020ma,also i connected it in parallel first time,2nd time in series,which still blew fuse.Another point worth mentioning is that to test that all systems shut down as they should then need to be woken up first. If the battery is disconnected, the reconnected this will not be the case. The method I use is to clamp the battery terminal with a long nose vise grips or similar and connect the metre. Start the car, switch it off, then remove the grips. This then allows the meter to maintain the circuit. If the circuit is not maintained the test may not be valid.
Better again, use a clamp on meter.
Also be aware, I saw a cheap metre that went open circuit for an instant as the range was changed.
I now have a UNI-T multi meter model no. UT33c,which has a 10a max capacity.I clamped the probes with crocodile clamps to the batt -terminal &neg clamp.
As you can see from post #20,the biggest drain culprit is the passenger memory seat.As to limit drain i have disconnected the passenger memory seat fuse,which brings the drain down from 1020ma to 290ma.
Is it possible to have this passenger memory seat unit tested as to confirm its broke,before i obtain a replacement?If anyone could recommend a company besides MB.
