mb240
I have fitted a Becker Cascade 7944 to the W208. Basically I have this bizarre problem of the headunit switching off automatically after an hour of being on. It makes the shutdown soft Beep and then if you press the power button quickly, it comes back on, or else it shuts down and you have to wait 5 seconds to turn back on.
This is totally weird. As a clue, the stereo does not come on and off with the ignition. I am thinking that there is some weird CANBUS power thing that is turning off after a while if it is not getting a signal from the OEM unit or something. Or, some weird Becker thing that is making you sit up and not fall asleep or something crazy like that.
The power comes from the standard ISO A-plug, and I just plugged it straight into the Becker (was an Audio 10 by Becker, circa year 2000).
Anyone got any ideas? It all works fine, but this hour thing bugs me - on a long journey I need to basically not fall asleep at the wheel
OR, probably the most logical, is that it turns itself off to not drain the battery - as it does not come on or off with ignition. ANy ideas on how I can correct this? Do I need to get something from the original wires that I am not using? Like make sure that the Switched Positive (pin 7 on A-block) is connected? ANd why the old Becker headunit came on and off with ignition and this doesn't....must be some CANBUS thing. And I have a CANBUS adaptor but am scared to use it! Hehe.
