Number_Cruncher
What you need to do is to work out why the spring came off - they don't just drop off for no reason! Is the spring OK, are the hooks at the ends OK? Are the bars over which the spring hooks at each end OK?
There's no adjustment to make to this system - you put the belt on, you tension the tensioner with the spring, and that's it.
The tensioner is just the arm which the lower end of the damper, and the spring connect to. All it is, is a pivot, with the spring pulling one way, and the belt the other, and the damper there to prevent excessive vibration. If the arm pivots OK, and the tensioner bearing spins OK, then there's nothing more that needs doing there.
