For me, Mobil 1 from Costco meets both tests!Think I paid about £24 for 5 litres last time.
Wow that must have been on offer or something at the time was it?
The .51 (as opposed to .5) is for cars with DPF.
The owners manual will specify which you should use - mine is 229.51, not 229.5 (and that's confirmed in the manual).
The label on my engine ( E280cdi ) says 229.31, but i don't have a DPF![]()
All diesels are noisy when cold, particularly modern common rail units which can sound very tappety, its quite normal. DPF = Diesel Particulate Filter.While we have the attention of oil connoisseurs, can you tell me if choice of oil will make any difference to the sound of tickover on my diesel C350. At the moment, it sounds like a tractor when cold and using VPower diesel has made no difference.
I have no idea what oil is in the car as it only nine months old, but I bought Castrol Edge 5w-30 for topping up. It has MB 229.51 on the label, and hope this is the right one.
What sort of improvement do you guys experience with, for example, Mobil 1? Is it worth asking the dealer to use this one at upcoming service?
(By the way, what is DPF??!)
Thanks...
