Blutooth connection W211 2002
axeman
Is it possible at reasonable cost to get a Blackberry with bluetooth to connect to the phone system in my new to me w211?:confused: :o
I'm assuming the car is not prewired. You could use the BT HF puck with Blackberry, you would not need the GSM antenna and antenna compensator in this setup but if the car is lacking cell phone support, you would need a control box, microphone and UHI connector plus the wiring between these (including MOST fibre loop passing the phone controller).
Can be done but it would be costly at the dealer, independent experts might do it at a reasonable cost if you don't want to try DIY.
Parts cost may appear on earlier posts.
http://www.mercupgrades.com/display_article_list.php
Thanks, car has phone display on instruments but probably no phonekit, certainly no cradle.
open the centre arm rest if there is a plug you have pre wire if not i was quoted £1200 for the pre wire kit from my mb dealer for my old ml 2 years ago so source a cheap alternative plenty of recomendations in here regards jon hope it helps:)
Being a 2002 model it will certainly not be UHI if it has any phone pre-wiring.
Dont expect any sort of decent integration to be cheap btw.
Prewire kits can be sourced a lot cheaper than that;)
