The first bodyshop I went to was recommended by a good friend (one of the most expensive quotes). Albeit he had work done on a very different type of car, an 80's Ferrari GTSGo by reputation, do you know anyone who has had work done from them?
So what should i pay for a full respray, on an estate, identical colour, bIt of rust correction lol.....?
Modern, water-based acrylic paints negate a lot of what you have said. Any bodyshop can afford infra-red lamps for drying.
No they don't, dust and contamination are the enemy of any paint job.
I kid you not a proper painter could produce a perfect paint finish anywhere
All a spraybooth is is a sealed room which has extraction and an oven non of which are necessary
Iv been involved in hundreds of jobs done in sheds ,barns ,lock ups ,even in drive ways up the side of houses lol
with water based + clear coat
respray are difficult but possible without a booth solid colours though are not really any more difficult
A craftsman is a craftsman if you know what your doing you will make it right ,the best painters make as good a job on a transit van wing as a Porsche respray because they can without thinking about it !
A lot depends on the quality of the bodyshop and its equipment. No matter when I discuss this I am always told that the bodyshop in question is top notch and does work for the Queen blah blah blah, but that fact remains if you go to a bodyshop in a backstreet garage with no dedicated passive certified paint booth with proper extraction and proper curing facilities then you will not get as good a job as one that does have that sort of set up no matter how good the sprayer.
That's why some cost £500 and some cost £1500 for the same job. If you are happy with the finish and work from the £500 shop go for it.![]()
Booths are simply a production line device
If we didnt have them it wouldn't be possible to get through a volume of work
After a job is painted 45 minute bake 10 minutes to cool then you can start putting it back together in and out same day for small jobs bumpers etc
That's the down fall of not having a booth waiting for the paint to dry !
